| Cadillac 4.1L V8 pistons https://slantsix.org/forum/viewtopic.php?t=66497 |
| Author: | Valleyant [ Fri Mar 04, 2022 6:07 pm ] |
| Post subject: | Cadillac 4.1L V8 pistons |
Are these pistons of any use in our slant 6 engines? Looks like they would drastically lower CR. Slants 1.74" vs Cadillacs 1.63" compression heights, not to mention the Caddys dish. |
| Author: | Doctor Dodge [ Fri Mar 04, 2022 7:32 pm ] |
| Post subject: | Re: Cadillac 4.1L V8 pistons |
The 3.465 bore size works but the 1.63 compression height (+ dish) and the .865 piston pin size are not a good match. DD |
| Author: | Valleyant [ Sat Mar 05, 2022 9:39 am ] |
Thank you, Sir, I appreciate the response. |
| Author: | Dart270 [ Sun Mar 06, 2022 3:39 am ] |
You could make these work with a 198 rod and/or with lots of block/head milling, but otherwise Doug is right. Lou |
| Author: | Valleyant [ Sun Mar 06, 2022 8:41 am ] |
Quote: You could make these work with a 198 rod and/or with lots of block/head milling, but otherwise Doug is right.
Yah in a pinch but not worth it..... I saw some for sale cheap and saw the bore size and wondered how close of a direct replacement....thanks
Lou |
