It is currently Wed Nov 18, 2026 12:48 am
PostPosted: Mon Jun 27, 2022 6:37 pm
Would a '60-'62 wagon have more spring rate than a typical 4 door / 2 door sedan/ hardtop from the factory?
Thanks!
PostPosted: Tue Jun 28, 2022 7:35 pm
Seems like a station wagon would have higher capacity rear leaf springs.
Unless someone has really good knowledge on that, maybe contact an aftermarket leaf spring manufacturer like ESPO. They may have access to part catalogs and engineering data from back when those cars were new.
PostPosted: Wed Jun 29, 2022 6:15 am
Spring part numbers from the 62 parts book. Valiant/Lancer
Standard..........................2275 851
EX Sub, w225 eng, R..........2298 934
EX Sub, w225 eng, L...........2298 935
Std Sub, R.........................2275 852
Std Sub, L..........................2275 853
Heavy Duty, Ex Sub, R...........2275 855
Heavy Duty Ex Sub, L............2275 513
Heavy Duty, Sub, R...............2275 856
Heavy Duty, Sub, L...............2275 857
PostPosted: Wed Jun 29, 2022 9:24 am
Thanks Charrlie, I should be able to decipher something from that..although it does not give me spring rate.
PostPosted: Wed Jun 29, 2022 11:13 am
I haven't seen spring rate in regular listed in any of the "standard" repair/service/parts manuals.
I am assuming "standard" is a sedan with a 170 engine.
"Sub" is for suburban or station wagon.
Found some aftermarket info. Don't know how it relates to the factory springs.
Regular rear spring is rated at 720 lbs, and 110 lbs/in
Heavy Duty is 800 lbs, and 130 lbs/inch
These are for 1961 to 1966. Got this info from Tampa Spring Co.
PostPosted: Fri Jul 01, 2022 5:49 am
Thanks Charrile for the excellent Information - It's Likely that I will need Somewhere in the 175-225 lbs/In Rate for my project aspirations, So I Suppose a set of Air Shocks or a spring Swap is in the future plans.
Cheers!
PostPosted: Fri Jul 01, 2022 6:51 am
I would suggest you contact a spring shop in your area (Tampa Spring is 25 miles from me). Tell them the spring rate you need. They should have the physical dimensions for the spring. Then they can build exactly what you want. You can even specify the amount of "arch" you would like. A quick google search shows a couple of spring shops in Pittsburg.
