It is currently Mon Nov 09, 2026 1:21 am
PostPosted: Sat Aug 27, 2022 11:35 am
Car Model: '66 Cuda Formula S - 4spd, sure grip, disc brakes
I got a 65 Cuda instrument cluster that I would like to test the fuel & temp, amp gauges. Can I use a multimeter? Having a hard time finding anything, just using a multimeter. I know I can't test gauge accuracy with it. Thanks in advance! :mrgreen:
'66 Barracuda Formula S
Modified 273 - factory options....center console, 4 speed & front disc brakes & 8 3/4 sure grip (3.55)
PostPosted: Wed Sep 21, 2022 2:14 pm
Car Model: 1966 Dodge Dart
You'll need resistors to check the gauges. Connect the resistor with alligator clips to the pin that goes to the sending unit in the wiring, and to your ground source. 73 ohms should be the bottom of the range and 10 ohms at the top.
Matt Cramer
PostPosted: Wed Sep 21, 2022 2:31 pm
Thanks....I did some research a couple weeks ago and figured out how to use the multimeter and then perform a separate test using AA batteries.
