It is currently Wed May 20, 2026 11:21 pm
PostPosted: Tue Oct 11, 2022 8:53 pm
Car Model: Mazda RX8 slant six swap
I just bought some Ausie Speed Dutra duals from Gill Welding (nice people). Is there a formula for calculating the length of the pipes before they go into the collector?
PostPosted: Tue Oct 25, 2022 5:15 am
Car Model: 1963 Dart Convertible
That length is proportional to where in the RPM band you want the peak scavenging for torque. I put my Y at about 42” which was about 3500 RPM. you will never know exactly without a dyno and testing but my modeling said between 40 and 60 should put it in the nice highway RPM for peak torque when passing and such.
Jim
PostPosted: Tue Oct 25, 2022 5:38 am
With Dutras, I'm not sure it will matter much, but putting it further back is likely better and that 42" number sounds about right. When I use headers, I put the Y junction 4 - 8" behind the trans X member.
PostPosted: Tue Oct 25, 2022 7:11 am
You can also Fill out the form here, And they may be able to help you out too!
