It is currently Thu Dec 25, 2025 9:35 pm
 Post subject: exhaust flang leaks
PostPosted: Mon Aug 25, 2003 3:29 pm
I thought I read a post about using window caulking between the manifols and tail pipe flange to seal leaks. I could not locate the post so I may have been mistaken on where I saw this trick.
Will this technique hold? :?:
 Post subject: Problems...
PostPosted: Mon Aug 25, 2003 3:45 pm
I recently had that happen, and I used some 'exhaust' cement (balck goo in a tube). It did the job, but I had enough pressure and heat built up I toasted the 'sandwich' between the intake and exhaust manifold.
What ever you use, you'll have to make sure it holds up to some pretty attrocious heat.
PostPosted: Mon Aug 25, 2003 6:16 pm
POR15 makes a product called fireseal2000 thats made for like cracks in exhaust manifolds, etc. I figure if that doesn't work, nothing will. No way caulking will hold you can easily melt that with a 15w soldering iron let alone the several kw of heat going out your tailpipe.
PostPosted: Mon Aug 25, 2003 9:06 pm
I went ahead and tried the window caulk trick on exhaust flange, after about a 5 mile run the stuff is holding up. The caulk seems to get very hard after it burns. I am holping some elasticity remains. But for now no exhaust leaks. I also used the same treatment on the flange I made to replace the rusted out choke pot.
PostPosted: Tue Aug 26, 2003 11:02 pm
I had heard a while back of a special caulking formulated to be used on exhaust systems. I think it was called Gorilla Snot, or something along those lines. Heard it was pretty good.
 Post subject: Gorilla Snot
PostPosted: Tue Aug 26, 2003 11:40 pm
This is the name of a product used by guitar players to help hold a pick when your hands sweat. Sorta like "stick'em". I wonder if it's the same as what you heard ...
"Nothing in all creation is hidden from God's sight. Everything is uncovered and laid bare before the eyes of Him to whom we must give account."
PostPosted: Tue Aug 26, 2003 11:44 pm
A quick search of "gorilla snot exhaust" turned up a few cases where people have used gorilla snot, aka the yellow colored 3M Super Weather strip adhesive, to hold things in hot places.
