It is currently Tue Nov 10, 2026 2:15 am
 Post subject: 65 Valiant speaker size
PostPosted: Tue Oct 17, 2023 4:29 am
Car Model: 1965 Valiant 200
What size would the front speaker be in a 65 Valiant? The car didn’t come with a radio or speaker, I found the correct am radio but have no idea what size speaker I need to buy.
PostPosted: Sat Oct 21, 2023 9:14 am
Car Model: 1966 Dodge Dart
My '66 Dart has a 6 x 9; I'm pretty sure Valiants would be the same.
Matt Cramer
PostPosted: Sun Oct 22, 2023 7:36 pm
Ok thank you. I'll try a 6x9
PostPosted: Mon Nov 06, 2023 3:44 am
The 6x9 would be the rear package shelf speaker size.
Front may be different. It's possible a 6 x9 might work up front too, but I believe the factory size for the front was a bit off those dimensions.
PostPosted: Mon Nov 06, 2023 11:50 am
I think I recall a 4" × 10" in my '65 D'Valiant, with one attaching point at each end (rather than the 4-corner fixing points of a 6 × 9) and this outfit offers a twin speaker on 4 × 10 mount bracket for the application.
PostPosted: Fri Nov 10, 2023 5:45 am
I know the 4x10's were in the front of the '67 Up cars but not quite sure on those earlier models.
I pulled all of the radio stuff out of my '64 Dart. It was all full of grit and nonworking, plus when I drive that car I am not enjoying the radio.
Good Luck!
PostPosted: Fri Nov 10, 2023 9:46 am
I know for a fact that I had a 6X9 mounted in the dash of my 65 valiant. It is a VERY tight fit to the wiper linkage. I believe I had it mounted to the plate that Dan mentioned in his post with a single nut on either end. I had a 4 speaker setup with all 6X9 speakers. One of the front channels was mounted in the center rear position.
