It is currently Wed Nov 11, 2026 4:42 pm
PostPosted: Fri Jun 14, 2024 10:50 am
Hello,
I am looking for the Press in Diodes for this:
Are such things available for separate purchase?
and are all the diodes the same or are there a few different ones in the group of 6?
the problem is 2 of them will no longer stay pressed into the body after I pressed them out for detail and cleaning of the alt. case and frame ~2 years ago. :(
Thanks for any info!
PostPosted: Fri Jun 14, 2024 12:48 pm
https://www.rockauto.com/en/catalog/dod ... ifier,2452
PostPosted: Fri Jun 14, 2024 12:54 pm
You can also get them from Amsco Valley Forge.
PostPosted: Fri Jun 14, 2024 3:04 pm
Awesome. I did not think they would be that easy to find.
Thank you.
Now, how many and which ones are negative and/or positive?
PostPosted: Fri Jun 14, 2024 4:27 pm
The negative ones are put right into the case directly.
jus sayin....
PostPosted: Sat Jun 15, 2024 6:58 am
Looks like Amsco does not sell to people. I have no account with them, and I am nor a business, so I will get them on Rockauto.
Thanks all!
PostPosted: Sat Jun 15, 2024 1:52 pm
Greg, I sent you a PM.
