It is currently Wed Nov 11, 2026 12:13 am
PostPosted: Mon Apr 08, 2024 8:19 pm
Car Model: ‘68 D-100 Utiline
Trying to get a ‘68 D100 running, and started going through the distributor today. Discovered the “star spring clip” that holds the two advance plates together was broken.
The distributor looks like it is usable otherwise, but can’t seem to find the spring clip online anywhere. Any suggestions on where to look? Or do I just need to get a whole advance plate assembly?
Thanks!
'68 D100 Utiine - work in progress!!
PostPosted: Tue Apr 09, 2024 12:36 am
If no one on here can help you, send me a PM and I will give you the contact info for someone that has these parts. I don't know if he wants his info on an open site. He is a member on forabodiesonly.com
His screen name over there is Halifaxhops
PostPosted: Tue Apr 09, 2024 4:53 am
Thanks! I can head over there and hit him up.
PostPosted: Tue Apr 09, 2024 6:34 am
Any old Mopar distributor should have that clip in there.
But the halifaxshops has it too, as Charrlie said!
PostPosted: Tue Apr 09, 2024 6:39 am
I've got two coming from halifax already - fantastic recommendation! Much appreciated!
