| Header flange material https://slantsix.org/forum/viewtopic.php?t=6772 |
| Author: | Slanted73 [ Mon Sep 01, 2003 10:35 pm ] |
| Post subject: | Header flange material |
On the header flange, does it have to be a stainless steel or will regular steel flat stock work? |
| Author: | shiftless [ Tue Sep 02, 2003 12:25 pm ] |
You can build a header out of mild steel, but it needs to be *thick* to prevent cracking. It will also be heavy. If you can weld stainless, do that instead. It doesn't have to be thick and will much lighter. |
| Author: | Slanted73 [ Wed Sep 03, 2003 5:02 am ] |
| Post subject: | re |
thanks |
