It is currently Fri Nov 20, 2026 8:16 am
PostPosted: Tue May 21, 2024 6:34 pm
This blast from the past showed up today.
O Stock 1960 Valiant, Hyper Pak, 3 speed manual!
This picture was from Englishtown in 1968.
PostPosted: Tue May 21, 2024 6:42 pm
Talk about a "paper" car...........
Paper car refers to a combination that was never available that shows up in Stock or Super Stock.
PostPosted: Tue May 21, 2024 6:55 pm
That's..... so.... Hyper!
PostPosted: Wed May 22, 2024 6:08 am
Very cool. Why not available? I thought the Hyperpaks were dealer installed, so why not a wagon? Just curious.
PostPosted: Wed May 22, 2024 6:30 am
Interesting, I occasionally raced at Englishtown back in the '60's. Early '60's with a 63 Ford Galaxy, later '60's a 60 Chevy Biscayne. Maybe that's why I don't recall that car. Didn't start racing Mopars until the mid '70's.
PostPosted: Wed May 22, 2024 6:45 am
It showed up in the NHRA classification charts early in the 60's.
That was the plan for my Lancer wagon years ago when I got it.
I have the gents name, going to try and contact him.
I don't think I would have tried that 3 speed though.
Can you imagine the clutches he burnt up.
I will try to find another picture.
PostPosted: Wed May 22, 2024 6:50 am
Pretty cool. On the front fender is says 170 cuin and 148HP.
PostPosted: Wed May 22, 2024 7:42 am
I wonder what times they run back in the day with 170
PostPosted: Wed May 22, 2024 8:54 am
Was there ever a 4 speed available in the early Toads?
A 170 wagon in O/S seems to be a pretty tough row to hoe. :oops:
PostPosted: Wed May 22, 2024 9:25 am
No, Chrysler four speeds did not arrive until 1964 with the development and introduction of the a833
If I remember correctly some larger (probably B / C bodys) were available from the factory with pont a mousson french 4-speed transmission.
here is some more research on the subject:
https://www.google.com/search?q=Pont-%C ... nt=gws-wiz
PostPosted: Thu May 23, 2024 11:16 am
I have never seen anything saying anything like no Hyper Paks on wagons; the only exclusion I ever saw was no Hyper Paks on automatics. Which makes sense because very high idle speed to accommodate the HP camshaft would make a car with an automatic unsafe/uncontrollable.
None of the parts in the Hyper Pak kit has any way of knowing or caring how many doors has the car they're installed in.
PostPosted: Thu May 23, 2024 1:57 pm
Because the HP kits were dealer/customer installed. Stock and SS had to be factory built. Since it turned up in the Guide somebody at Chrysler had to write a letter, hence the term "paper car".
Mopar was well known for "ringer" cars, but they were not the only ones. It still goes on today.
PostPosted: Thu May 23, 2024 6:36 pm
As far as the automatic warning, I remember seeing that in the factory documentation.
When I did my wagon, I was not sure how it was going to work.
I used a stock automatic throttle rod and lengthen it.
It all worked great.
But autos in the early 60 were still kind of a mystery.
PostPosted: Thu May 23, 2024 6:49 pm
Plus the Hyperpak cam is not large by any standard except "larger " than stock. I run a bigger cam than that in my full size truck right now.
PostPosted: Thu May 23, 2024 8:36 pm
The HP cam wasn't even .500" lift, was it? Lawnmower crap. :mrgreen:
