It is currently Mon Oct 12, 2026 2:29 am
 Post subject: Flywheel torque spec
PostPosted: Thu Jun 13, 2024 4:54 pm
Car Model: 1966 Plymouth Valiant
does any know the torque spec of the flywheel bolts on a stock 1966 225?
 Post subject: Re: Flywheel torque spec
PostPosted: Fri Jun 14, 2024 1:13 am
If you mean flywheel to crank hub, then I believe it is 55 ft lbs. However, I ALWAYS torque mine to 65-75 ft lbs and use red loctite so they do not vibrate loose.
PostPosted: Fri Jun 14, 2024 6:43 am
Thank You
