| Flywheel torque spec https://slantsix.org/forum/viewtopic.php?t=67790 |
| Author: | J S Goldman [ Thu Jun 13, 2024 4:54 pm ] |
| Post subject: | Flywheel torque spec |
does any know the torque spec of the flywheel bolts on a stock 1966 225? |
| Author: | Dart270 [ Fri Jun 14, 2024 1:13 am ] |
| Post subject: | Re: Flywheel torque spec |
If you mean flywheel to crank hub, then I believe it is 55 ft lbs. However, I ALWAYS torque mine to 65-75 ft lbs and use red loctite so they do not vibrate loose. Lou |
| Author: | J S Goldman [ Fri Jun 14, 2024 6:43 am ] |
Thank You |
