It is currently Sun May 10, 2026 4:44 pm
 Post subject: '85 D100 truck
PostPosted: Wed Sep 03, 2003 2:36 pm
Terrible klunk going into reverse, forward is ok. U-joint? Broken mount? Any thoughts?
Thnx, Jim
PostPosted: Thu Sep 04, 2003 5:28 am
I bet if you look, your passenger side engine mount is mia.
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
PostPosted: Thu Sep 04, 2003 7:14 am
I had a '74 W100 I bought new and it did this. Not knowing anything at the time, the dealer said it was normal :? . I did put 70,000 hard miles on it and didn't have a problem but I never got used to the clunk. If I had the truck today, I'd pull the tans pan and check for a misadjusted reverse band or sticky servo.
Cecil
PostPosted: Thu Sep 04, 2003 9:31 am
...not sure abot trucks, but there was a TSB on my '85 Fifth Ave and others around that year with the 904 based trans. There was a kit available for dealers to install in the valve body to make the N to R clunk less harsh. We'd have to do a little more research on that angle.
"DW"
If it ain't broke, fix it!
PostPosted: Thu Sep 04, 2003 4:06 pm
