Help with transmission swap if it it fits.
https://slantsix.org/forum/viewtopic.php?t=67914
Author:  Slantsix83 [ Mon Sep 09, 2024 7:11 pm ]
Post subject:  Help with transmission swap if it it fits.
I have a 1983 d150 slant six with a ford 4 speed transmission not sure what type. I saw on ad on Facebook of this guy selling a New Process NP435 4-speed transmission manual with bell housing for Dodge flywheel, clutch, pressure plate, driveshaft, PTO (Power Take Off) gearbox. Included would this fit my slant six if not what would I need to do. He says it came from the factory on a 440. Also is this a granny transmission or would acceleration be quicker.
Author:  Rick Covalt [ Tue Sep 10, 2024 6:36 am ]
Post subject:  Re: Help with transmission swap if it it fits.
No it won't fit. If it was on a 440 then the belhousing, flywheel...etc is different than a Slant 6.
Author:  volaredon [ Tue Sep 10, 2024 10:24 am ]
That NP435 was used in both Dodge and Ford
What "Ford trans" is in your truck?
The 435 had a removable bell housing, with the right bell housing and flywheel that trans could go behind a /6.
Author:  Slantsix83 [ Tue Sep 10, 2024 4:02 pm ]
Could I get that all separately so it can fit
Author:  Slantsix83 [ Tue Sep 10, 2024 4:03 pm ]
No clue all I know is that it's a 4 speed. Couldn't really ever find any information on it what used parts could I find for the transmission to fit.
Author:  hank2 [ Tue Sep 10, 2024 11:25 pm ]
Your '83 D150 (2wd) slant would have had an A833OD 4 speed with super tall .71/1 top gear. Anything 4wd (W100 and up) and any D/W250, D/W350 would have had the A435 heavy duty trans with grannie 1st gear.
Author:  Slantsix83 [ Wed Sep 11, 2024 5:48 am ]
I really don't think it's the A833 I'll take pictures of it when I change out the throw out bearing. Because when I replaced the clutch I was told it wasn't a dodge but a ford clutch.
Author:  Slantsix83 [ Wed Sep 11, 2024 5:52 am ]
Here are the bottom pictures If you can id the transmission.
Author:  Charrlie_S [ Wed Sep 11, 2024 6:39 am ]
For sure not a 833 OD. That is a "top loader".
Author:  Slantsix83 [ Wed Sep 11, 2024 7:16 am ]
I've been having issues trying to id the transmission. All I know is that it's a ford since it has a ford clutch in it.
