It is currently Fri Dec 26, 2025 7:39 pm
PostPosted: Tue Dec 16, 2025 8:08 am
Hey hoarders, I need a chunk of aluminum plate to make an adaptor.
I am going to weld it so I don't want to use any cast metal.
Also going to tap holes so no space age metal either.
5 X 6 and a 1/2 inch thick.
Any stuff in your scrap metal piles?
Thanks in advance.
PostPosted: Tue Dec 16, 2025 9:16 am
I may be able to cut a piece out of a big plate I have. Need to look at what I have. When do you want/need it? Call/text me on Saturday to remind me if I've not responded.
PostPosted: Tue Dec 16, 2025 10:00 am
Hi Stan,
No 1/2" thick stuff in my scrap pile.
Check with your local fab/machine shops to see what they would sell you.
PostPosted: Tue Dec 16, 2025 12:07 pm
Thanks Lou
I am welding a flange on the Feather Duster intake.
PostPosted: Tue Dec 16, 2025 3:09 pm
McMaster-Carr has it, but it's salty.
PostPosted: Tue Dec 16, 2025 8:13 pm
Car Model: '23 T-bucket
You might also look on Ebay and Amazon.
Roger
PostPosted: Wed Dec 17, 2025 7:23 am
Roger
Thanks Roger
PostPosted: Wed Dec 17, 2025 9:28 am
Stan if Lou doesn't have any I can get a piece cheap. Would take a couple days to stop by the welding shop. I will also check my pile.
PostPosted: Thu Dec 18, 2025 1:33 pm
Folks, I mocked up the base plate and I seem to think I might need to be closer to 1 inch.
I could weld the 1/2 to the manifold and then add a 1/2 spacer between the base and the carb flange.
This is a Holley Progressive 350 2 barrel.
Not a Weber, a real Holley.
If y'all come up with some scrap let me know.
PostPosted: Fri Dec 19, 2025 2:52 am
Why so thick? Maybe take 5/16" or 3/8" thick, then drill and tap for studs and put a spacer between the carb and plate. Easy to find cheap spacers for that carb, I think.
PostPosted: Fri Dec 19, 2025 7:47 am
The sideways linkage swings through a big arc and it's on the manifold.
I have only found decent spacers adapters at speedway motors.
PostPosted: Sat Dec 20, 2025 8:19 pm
Check with Metals Depot, see what they have for You, I've sourced from them for years...
PostPosted: Sun Dec 21, 2025 1:45 pm
Now that you need 1" instead of 1/2" I have some.
Send me a message etc and we can work something out.
