It is currently Thu Jan 29, 2026 11:51 pm
PostPosted: Tue Jan 13, 2026 3:53 pm
Working on cleaning out my garage.
For some reason I saved the head pipe from a single barrel F body (Aspen/Volare). Will fit M/J/R bodies as well (Diplomats, LeBarons, Cordobas). Pipe runs from the exhaust manifold, down under the oil pan in front of the transmission, then turns and runs towards the back of the car on the passenger side. Has the factory bracket that bolts to the transmission mount to support the pipe.
Factory pipe, 1 7/8 inches outer pipe diameter, 1 5/8 inches inside pipe diameter.
Would be great for someone wanting to switch to dual exhaust manifolds with a factory rear manifold. Just add a second 1 5/8 pipe for the front the cylinders and double your exhaust capacity.
You pick up from my garage in Tacoma, WA. FREE.
