It is currently Thu Oct 22, 2026 3:25 am
 Post subject: Run it or Chuck It?
PostPosted: Fri Feb 06, 2026 11:56 am
P4529343 Purple Shaft .528 Lift, 284 Duration
What do you think?
 Post subject: Re: Run it or Chuck It?
PostPosted: Fri Feb 06, 2026 12:31 pm
Its on the base circle?
I bet it will be fine @ 0.028" or so
If you want to / decide to throw it away,
I have a lead on someone looking for one of those 0.528" cams.
PostPosted: Sat Feb 07, 2026 4:01 am
Agree with Greg. If on base circle, you are good to go most likely. That should be a great cam for 10-10.5:1 or so motor.
PostPosted: Sat Feb 07, 2026 9:11 am
Or a great lobe wiper. Not because of your corrosion. There was just a bad bunch of the .528 cams that wiped lobes. But you probably already knew that. I'd take some crocus cloth or similar to it an run it.
PostPosted: Sat Feb 07, 2026 9:25 am
It has been run, I do not have any history on it.
PostPosted: Mon Feb 09, 2026 5:22 pm
There was a batch of .528s that killed oil pump gears too.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 27 guests
