Run it or Chuck It?
https://slantsix.org/forum/viewtopic.php?t=68528
Author:  hyper_pak [ Fri Feb 06, 2026 11:56 am ]
Post subject:  Run it or Chuck It?
P4529343 Purple Shaft .528 Lift, 284 Duration
What do you think?
Author:  Greg Ondayko [ Fri Feb 06, 2026 12:31 pm ]
Post subject:  Re: Run it or Chuck It?
Its on the base circle?
I bet it will be fine @ 0.028" or so
If you want to / decide to throw it away,
I have a lead on someone looking for one of those 0.528" cams.
Author:  Dart270 [ Sat Feb 07, 2026 4:01 am ]
Agree with Greg. If on base circle, you are good to go most likely. That should be a great cam for 10-10.5:1 or so motor.
Author:  Rick Covalt [ Sat Feb 07, 2026 9:11 am ]
Or a great lobe wiper. Not because of your corrosion. There was just a bad bunch of the .528 cams that wiped lobes. But you probably already knew that. I'd take some crocus cloth or similar to it an run it.
Author:  hyper_pak [ Sat Feb 07, 2026 9:25 am ]
It has been run, I do not have any history on it.
Author:  slantzilla [ Mon Feb 09, 2026 5:22 pm ]
There was a batch of .528s that killed oil pump gears too.
