It is currently Sat Apr 25, 2026 9:56 am
PostPosted: Tue Mar 17, 2026 9:25 am
Car Model: Clark Cortez 1964
I am located in New Haven Vermont and have 2 slant 6 engines,1 whole, 1 disassembled. Came out of Clark cortez Motorhomes from the mid 60s. Let me know if you would like these otherwise they will be scrapped.
Clark Cortez with /6,
Side draft Carter YH
Dutra duels, 2.5” pipe back from wye
Possibly an RV cam
PostPosted: Tue Mar 17, 2026 11:25 am
I would be interested in (2) camshafts and (2) oil pumps.
I will be up your way between the last week of June and July 4th, 2026. I would not be able to take an entire engine, but those 4 parts if it works for you.
You can Private message me the details if you like.
Thank you,
PostPosted: Tue Mar 17, 2026 4:57 pm
Do we think these might be Industrial Blocks?
PostPosted: Tue Mar 17, 2026 8:06 pm
Car Model: '23 T-bucket
That intake and Carter YH might be an interesting conversation piece.
Roger
PostPosted: Wed Mar 18, 2026 1:40 pm
Remember, there was no special block for industrial engines. There were several different levels of truck engine (225-1, 225-2) with various heavy-duty upgrades, but these used the same blocks as passenger car engines.
PostPosted: Wed Mar 18, 2026 5:02 pm
I was led to believe that Industrial Blocks had a higher Nickel content.
PostPosted: Wed Mar 18, 2026 5:20 pm
Yup
I was thinking the same about that intake and carb being interesting.
But way too far away for me to go.
I do hope they get scooped up as so many were scrapped and they ain't making any more
PostPosted: Wed Mar 18, 2026 6:30 pm
The carbs and intakes were Damaged by the Salvage yard So they are scrap. I have the crank and cam for the engine that I took apart. I might have the oil pump, I have to see. It sounds like the rest will go to the salvage yard
Possibly an RV cam
PostPosted: Wed Mar 18, 2026 9:56 pm
That is not the case. It's a fairytale.
Groan. How on earth did they manage that‽ I mean, okeh, a carb is a small potmetal thing with a bunch of delicate parts. But an intake‽
Cortez-specific valve cover(s) still around?
PostPosted: Thu Mar 19, 2026 4:09 am
Why do you think nobody will rescue these parts and they'll end up in scrap?
PostPosted: Thu Mar 19, 2026 11:44 am
Possibly an RV cam
PostPosted: Thu Mar 19, 2026 4:33 pm
He probably thinks that because the odds are he's right. :-(
PostPosted: Thu Mar 19, 2026 5:15 pm
I could keep them around a little longer, but they would be outside on a pallet under a tarp. I've got limited space and Slant 6s take up a lot of room.
Possibly an RV cam
PostPosted: Fri Mar 27, 2026 11:17 am
Car Model: Slant Six M37
I'm just seeing this for the first time.. and I am interested... I will send you a Private message to establish contact info, and see about picking up what remains that have not be spoken for.. OR pick it all up if you are in a rush to get rid of it.. and then work to distribute the parts
Jason
