It is currently Sat Nov 07, 2026 8:54 pm
 Post subject: lower hinge
PostPosted: Sat May 16, 2026 2:45 pm
Car Model: 1963 Plymouth Valiant 2dr
In looking for lower door hinges for my 63 A body I found dormen 924-108 works great. You have to drill one hole and it fits great. Hope this helps someone!
 Post subject: Re: lower hinge
PostPosted: Sat May 16, 2026 3:22 pm
I don't know if all of the bodies are interchangeable but I do know that the later a bodies take the same hinges as an 80a truck. That might help someone whose looking for them
Full size vans too
PostPosted: Sat May 16, 2026 5:07 pm
Yup, that's the truck hinge. Yup, it works on A-bodies.
'63-'65 A-body front door hinges are all identical, position by position (lower left and lower right are different, upper left and right are same).
1966 lower hinges are different from '63-'65 (uppers are same), but the '66 lowers are fit/function interchangeable with the '63-'65 lowers.
'67-'76 lower hinges are the same as '66 lower hinges.
'72-'93 Dodge D/W-series pickup truck and '71-'97 Dodge B-series van lower hinges are the same as '66-'76 A-body lower hinges.
