| lower hinge https://slantsix.org/forum/viewtopic.php?t=68642 |
| Author: | Billy37 [ Sat May 16, 2026 2:45 pm ] |
| Post subject: | lower hinge |
In looking for lower door hinges for my 63 A body I found dormen 924-108 works great. You have to drill one hole and it fits great. Hope this helps someone! |
| Author: | volaredon [ Sat May 16, 2026 3:22 pm ] |
| Post subject: | Re: lower hinge |
I don't know if all of the bodies are interchangeable but I do know that the later a bodies take the same hinges as an 80a truck. That might help someone whose looking for them Full size vans too |
| Author: | SlantSixDan [ Sat May 16, 2026 5:07 pm ] |
Yup, that's the truck hinge. Yup, it works on A-bodies. '63-'65 A-body front door hinges are all identical, position by position (lower left and lower right are different, upper left and right are same). 1966 lower hinges are different from '63-'65 (uppers are same), but the '66 lowers are fit/function interchangeable with the '63-'65 lowers. '67-'76 lower hinges are the same as '66 lower hinges. '72-'93 Dodge D/W-series pickup truck and '71-'97 Dodge B-series van lower hinges are the same as '66-'76 A-body lower hinges. |
