It is currently Sat Nov 14, 2026 7:42 am
PostPosted: Thu May 21, 2026 4:54 am
Car Model: 1985 Dodge Ram W100
Hello People I am in need of this set up 77-'83 Slant-6 2-barrel item. You'll need the sheet metal "stove" that surrounds the central collector area of the exhaust manifold, and the flexible duct pipe that goes from that stove to the underside of the snorkel of the air cleaner. If anyone has this please send me contact info Thank you Greg
PostPosted: Thu May 21, 2026 7:12 am
This is not a two barrel specific item. I beloieve you are referring to the heater ait intake collector that bolts around the exhaust pipe. There were several designs used over the years, but one one from a single barrel setup can be used with a two barrel setup. The flexible metal tube can be purchased in bulk from any decent auto parts store.
PostPosted: Thu May 21, 2026 8:05 am
I just scrapped one of those hot box air shields. I had it posted, but no takers.
Good Luck,
PostPosted: Thu May 21, 2026 12:51 pm
OP needs an air cleaner assembly ('77-'83 225-2bbl or '70-'88 318-2bbl) and the stove, and the flex duct from the stove to the underside of the snorkel.
