It is currently Tue Jun 23, 2026 5:18 am
PostPosted: Sat Sep 13, 2003 12:21 pm
does any one have a source for a serpentine system for a 78 slant with pwr steering and a/c -the smog pump?
 Post subject: pulleys serp
PostPosted: Wed Nov 12, 2003 3:40 pm
we can modify one of are dampers for the bottom pulley, plus get youmost of the other ones also, olny problem that i can see is the a/c pump and how the run a belt tensioner e-mial fishercon1@aol.com
PostPosted: Wed Nov 12, 2003 9:24 pm
I've been looking around for the same. So far, I haven't found out much except that instead of a tensioner pulley, you can use an adjuster arm to tighten on the alternater to the right tension. I haven't gotten around to comparing 318 pulleys to 225's. I'm thinking something has to swap in there.
Slant Six... out of the ordinary - just like me!
PostPosted: Wed Nov 12, 2003 10:25 pm
What's the attraction behind a serpentine system? The way I look at it you loose one belt you loose every accessory instead of only some....
 Post subject: re: attraction
PostPosted: Wed Nov 12, 2003 11:46 pm
Serpentines are supposed to be less drag than V-belts. Sure you're down to one belt, but they're meant to last 50k miles. Other than that, I just like the look of them.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
