It is currently Sat May 23, 2026 12:50 am
PostPosted: Fri Oct 10, 2003 7:52 am
Car Model: 1965 2 Dr Sedan, Wagon, Barracuda and Convertible
Hello All,
I'm finally tearing down my 833. I'm rebuilding my spare because the noise from the one in my car is starting to scare me. As I started to tear down my spare I realized it is in very good shape. I should have probably just stuck it in. Oh well. This is a hobby right? Half the fun is doing something you've never done before. So, at the risk of destroying it. I ripped it apart. I already have a couple of questions.
1. How do I get the bearings off. Can they be removed with a drift and hammer? Should I take it to a shop and use a press.
2. What kind of snap ring pliers do I need. I have a couple of sets but they're all the kind that poke in a little hole. I've looked on the web and don't see anything like what I need.
3. Does anyone know the PN for the extension shaft seal. (It's an early 833 with the output flange).
I'm Sure there will be more questions. Thanks for the EXCELENT article on transmissions. I also have the shop manual, Haynes, and Chiltons. I'm armed to the teeth. No excuses!
http://homepage.mac.com/mandreas/MyVehi ... bum27.html
1965 Valiant 200 /6 2dr Sedan.
1965 Valiant 200 V8 4dr Wagon
1965 Barracuda /6
1965 Valiant Convertible V8
PostPosted: Fri Oct 10, 2003 8:42 am
I'd have a shop press off the old bearings and press on the new ones.
 Post subject: ?
PostPosted: Fri Oct 10, 2003 4:56 pm
I got mine from Sears, years ago. I've seen them elsewhere, but I can't remember where. If you find them, you may have to grind the pads a little bit, so they fit right.
'66 Cuda 225/4spd
'66 Dart GT convertible 225/auto
'64 Dart GT 340/4spd
 Post subject: Sears comes through
PostPosted: Fri Oct 10, 2003 8:47 pm
Part number 9 47386 $14.99
1965 Barracuda /6
