It is currently Fri May 15, 2026 4:25 am
PostPosted: Fri Oct 10, 2003 10:14 am
Are there large bolt pattern axels that I can swap into my stock 7.25 rear end? and what vehicles do they come out of. Thanks.
PostPosted: Fri Oct 10, 2003 1:16 pm
We recently went over this subject and the 1973-1976 LBP axles shafts are shorter than the pre-1973 units, for the price you'll pay at the junkyard it'd be cheaper to find a good 1973-1976 A-body(if that's what you have) and buy the whole unit and slide it under there and install it.
PostPosted: Wed Oct 29, 2003 1:58 pm
Thanks DI; Yes it's a 72 Swinger. What does LBP stand for?
PostPosted: Wed Oct 29, 2003 2:37 pm
Large Bolt Pattern (4.5" Bolt circle) as opposed to Small Bolt pattern (4" bolt circle)
PostPosted: Wed Oct 29, 2003 6:23 pm
The LBP axles have a different bearing on them and won't fit an SBP housing anyway. :shock:
PostPosted: Tue Nov 11, 2003 4:12 pm
good thing i read this before i yanked just the axels and backing plates from LBP 7.25 rear....i'll have to call the JY and tell them to hold the whole rear.
also the U joint is the same between the two rears right??
thanks
PostPosted: Tue Nov 11, 2003 7:28 pm
thanks
Yes. :D
PostPosted: Wed Nov 12, 2003 4:07 pm
How hard is it to install large bolt pattern axles on a car. I have a 73 Dart and could shoot the guy that thought a small bolt pattern would be a good idea. Do the large bolt pattern axles take 13 inch tires too? Is there an axle that will fit that can take larger tires? Eventually I would like to get nice wheels and in the 13 in realm your choices seem to be limited to tires that would only look good on a car with disc brakes, I don't really want to show off my rusty drum brakes. :wink:
My car may be slow to sixty, but at least it's been reliably slow to sixty for more than thirty years.
PostPosted: Wed Nov 12, 2003 4:32 pm
your car should have 14inch wheels on it unless it has the 9 inch drums and someone decieded to put smaller rims on it. also, some 73 base model cars came with the small bolt pattern from the factory.
PostPosted: Thu Nov 13, 2003 6:38 am
No, I'm fairly sure my car has 13 inch tires, and considering the care my car's had I doubt if they did a swap(who would switch to smaller tires?) I guess it's possible, but they'd have to change the hubcap size too and my hubcaps look very factory. Then again, maybe I'm thinking wrong, but I could also send the wheel size I'm using(as to give an idea of my tire size).
PostPosted: Thu Nov 13, 2003 9:53 am
"From the owner of Shiva, my 73 Dart goddess."
Better check the sex of your Dart - Shiva the Destroyer was a male God of the underworld.
:twisted:
PostPosted: Tue Nov 18, 2003 12:13 am
The swapping of the rear axle is only half of the equation. Don't forget the other two wheels up front. You probably want them to be the same bolt pattern, so you don't have to carry two spare tires. :shock:
Jerry
