It is currently Tue Nov 17, 2026 9:55 am
 Post subject: A-body question
PostPosted: Sat Oct 25, 2003 1:08 pm
I just wanted to know if a volare was considered an A-body?
Hellbent Rods & Custom fabs
PostPosted: Sat Oct 25, 2003 1:20 pm
Nope, Volare is an F body. In 77 I believe A body line was stoped and the F body line replaced it.
PostPosted: Sun Oct 26, 2003 4:39 am
The last 'A' bodies (Dart/Valiant) were built around December 1976.
The new 'F' bodies (Aspen/Volare') were brought out during the winter of '76/77'.
PostPosted: Sun Oct 26, 2003 5:19 am
Don't forget Dusters are also A bodies
PostPosted: Sun Oct 26, 2003 9:22 am
If you want to get technical, there was also a 'F' body Duster as well as some front drive 'N' body (?) models. :D
PostPosted: Sun Oct 26, 2003 10:10 am
Let's not forget the sister cars....
and the 1976 model year cars rolled out to the public October 16, 1975. Final production line assembly occurs in the first 2 weeks in July. Assembly of the 1977 models starts on August 1,1976....introduction of the 1977 models occured October 1, 1976.
PostPosted: Mon Oct 27, 2003 11:51 am
There is nothing technical about it Dusters are A-Bodies. The duster name has been used for other cars since the Volare Duster. the turismo had a duster model and the sundance as well. of the 3 latter none are A-Bodies nor are they the model name only a trim level.
PostPosted: Tue Nov 04, 2003 6:02 am
as hinted above, there are different abodys to be aware of when buying parts.
63-66 "narrow" abody use a different k-frame then the later models.
67-76 abody vary from the 67-9 a-barracudas to the duster, demon, scamp, dart, dart sport, standard valient.
