Slant Six Forum https://slantsix.org/forum/ |
A miss at idle https://slantsix.org/forum/viewtopic.php?t=7435 |
Author: | Spookyb4 [ Tue Nov 04, 2003 10:50 am ] |
Post subject: | A miss at idle |
I seem to have a miss at idle that dissapears sometimes. Everything on motor is new, carb, distributor, cap, rotor, wires, and plugs. The vehicle runs fine while being driven. Checked for vaccum leaks. I am new to slant sixes, but have worked on everything in the past. Worked on it this afternoon and found a dead plug. They are Autolite OEM replacements and only a week old. Any suggestions for plugs ![]() ![]() |
Author: | jsbgraphics [ Tue Nov 04, 2003 11:43 am ] |
Post subject: | |
If it were me I would check the valve adjustment. My 75 dart had a rough idle until I adjusted the valves, then no more skip. JB |
Author: | Patrick Devlin [ Tue Nov 04, 2003 4:09 pm ] |
Post subject: | |
Make sure the wires are firmly attached to the distributor cap and the plugs. If a wire is loose, that plug will not fire and it'll appear as a fouled plug. Look and see if the wire terminal on the plug that wasn't firing has a carbon build up on it. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
