It is currently Wed Apr 29, 2026 1:42 pm
 Post subject: Quick 904 Question
PostPosted: Sat Nov 08, 2003 10:55 am
hey, would a non-lockup VB out of a 77Volare wagon work in an 80lockup transmission? i probably already know the awnser but i just want to be sure :?
thanks
Justin
PostPosted: Sat Nov 08, 2003 3:40 pm
No. Lockup trans needs the hydraulic passages in the VB in order to work.
PostPosted: Sun Nov 09, 2003 7:49 pm
Hey Eric..
yea figured.. oh well, time to get rid of the lockup :twisted:
Justin
PostPosted: Sun Nov 09, 2003 8:36 pm
What's wrong with the lock-up tranny?
PostPosted: Mon Nov 10, 2003 1:01 pm
nothings really wrong with it, this is in a 80 4dr Volaré that will have a pretty radical cam and will be used for street/strip use.
lockups arent that great for strip so its time to "upgrade"
The reason i asked this Q is because when installing a trans kit i lost a little cam out of the VB. i found it and its running perfect again :)
Justin
PostPosted: Mon Nov 10, 2003 6:50 pm
I imagine if you don't want the lock-up feature you could just put a little plug in which ever end of of the lock-up valve to keep it from going to lock-up position.
