It is currently Thu Jun 04, 2026 2:45 pm
PostPosted: Sat Nov 15, 2003 8:07 am
Question for Carter BBD - vacuum piston assembly:
Should the tiny wire spring be in front or behind the metering rods? Also, do I have the metering rods properly postioned in the assembly? (Refer to "front" image)
Or
PostPosted: Sat Nov 15, 2003 11:55 am
Metring rods are ok. The tiny spring should go in the back of the rods.
See if this helps, :lol: although the quality of your pics is a lot better he he.
Rafa
Hecho en México
PostPosted: Sat Nov 15, 2003 6:52 pm
the springs go "behind" like your second picture. they just keep the rods from flopping around in the jets and the hangers.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
