| Do I have this installed right? https://slantsix.org/forum/viewtopic.php?t=7558 |
| Author: | pantseatflyer [ Sat Nov 15, 2003 8:07 am ] |
| Post subject: | Do I have this installed right? |
Question for Carter BBD - vacuum piston assembly: Should the tiny wire spring be in front or behind the metering rods? Also, do I have the metering rods properly postioned in the assembly? (Refer to "front" image) ![]() Or
| Author: | Seis Inclinado [ Sat Nov 15, 2003 11:55 am ] |
Metring rods are ok. The tiny spring should go in the back of the rods. See if this helps,
| Author: | Craig [ Sat Nov 15, 2003 6:52 pm ] |
the springs go "behind" like your second picture. they just keep the rods from flopping around in the jets and the hangers. |
