It is currently Tue Apr 28, 2026 11:21 pm
 Post subject: Do I Smell A Fight?
PostPosted: Fri Dec 05, 2003 9:16 pm
double post :roll: sorry
PostPosted: Sat Dec 06, 2003 6:16 am
hi, for racing only, use type f or synth. for more street, use mercon/dextron. type f has less friction modifiers to allow quicker "bite" on bands and clutches. the problem for street driving with type f occurs on the 2-3 shift, when the bands and clutches are applying and realeasing. for the split second that they overlap each other on the shift cycle , the type f fluid, because it's "grippy", hangs on to the drum band longer which shortens clutch pack life. you don't want a band hanging up, while the little clutch packs are trying to apply pressure. there are tech articles that show how street driving wears the cluch packs sooner with type f fluid. read and search before you pour it in. ron .
