It is currently Sun Nov 22, 2026 5:48 pm
PostPosted: Sat Dec 06, 2003 2:59 am
What dual reservoir master should I use to replace my single? I know that with certain m/c you need a proportioning valve and others the wheel cylinders do it, so that maens I need one that has the same size reservoirs? I plan on running the front brakes to one the rears to the other(just incase I want to put a line lock on it in the future), any help on the brake subject would be great, thanks.
-Jesse
PostPosted: Sat Dec 06, 2003 5:07 am
If this a front drum vechicle, no proportioning valve needed. Use a MC from 67 up with drum brakes. If you have power brakes, same drill, use one 67 up with power brakes. If you converting to Disc front then use whatever P valve that will match the master cylinder.
