It is currently Fri Nov 20, 2026 9:07 pm
PostPosted: Mon Dec 08, 2003 9:15 am
Hi All,
I have screwed around with the sender on my 65 barracuda for a couple of months now. It wouldn't read above 1/2 a tank, ( this is after fixing the voltage regulator, and checking it against just grounding the sender wire, so I know it was the sender) The sender was rusty beyond belief and the little wiper/finger portion was pretty damaged.
Layson's says that 63-66 interchange for A bodies. Do later model pickup/senders fit? Rob suggested that other years might fit. Whatta ya think?
Thanks,
PostPosted: Mon Dec 08, 2003 11:44 am
I have a '67-up sender (don't remember exactly which year) in my '64 Dart and it has worked fine. The pickup socks may be different, but those are easy to get.
 Post subject: Thanks Lou
PostPosted: Mon Dec 08, 2003 1:08 pm
I can always count on you to know the answers to some obscure problem that I am having. I am not worried about the sock, but the pickup is at the right height in the tank, and the circular part that mates with the tank itself is correct?
Thanks,
PostPosted: Mon Dec 08, 2003 5:07 pm
Circular part - yes. Height is, I believe, the same. I can't remember if I had to bend the tube a little or not - no big deal, eh?
PostPosted: Tue Dec 09, 2003 8:34 am
Sending unit is still available from MOPAR. Part #4051004 fits all models of 'A' bodies $84.20.
