It is currently Thu Apr 23, 2026 12:01 am
 Post subject: disk break change?
PostPosted: Thu Jan 15, 2004 10:26 am
I have found a 1976 dodge dart swinger 4 door will the front break system be the same as on a 2 door i want to change my 1969 dart gt to disk from drums
PostPosted: Thu Jan 15, 2004 10:32 am
Yep, they're the same. Grab all the brake parts, spindles/UCAs, and master cyl and distribution block.
PostPosted: Thu Jan 15, 2004 5:27 pm
Double check the wheel bolt pattern, I think theyre different. You can always use the front tires and rims from the 4DR, though
PostPosted: Thu Jan 15, 2004 8:13 pm
http://www.waywardmusclecars.com/tech/brakes.html
Disc Brake swap goood..... I've done it on five vehicles already, my new Valiant will be the sixth. Very happy with both the 11" and 11.75" rotors. Bolt pattern wise, either swap in the rearend, too, or BUY A PAIR OF ADAPTERS!!! Keep your original front wheels, or adapt the rear to the more common 5 x 4.5 bolt pattern.
TRD-7066 Wheel Adapter 5-lug car 5 on 4`` to wheel 5 on 4 1/2`` bolt pattern Tomorrow $39.99
Transdapt sells 'em, get yours today through Summit Racing.
Scott - waywardgarage.com
Why is the rum always gone? Image
