| Carb Insanity https://slantsix.org/forum/viewtopic.php?t=8130 |
| Author: | Factoids73Dart [ Fri Jan 16, 2004 4:28 pm ] |
| Post subject: | Carb Insanity |
I just recently purchaced a remanufactured Carter model 2297 carb, 2bbl to replace my Holley carb. I don't think its a BBD as recommended, but it will fit on the manifold. ( i.e. Carb Leak post) Anyhow, I am running into the same problem with this carb as with the last one... lack of info. I can supply a photo if that will help the situation. I am wondering about just general set-up of the carb. Thanks |
| Author: | Doc [ Fri Jan 16, 2004 6:19 pm ] |
There is a lot of carb. adjustment info in this article, see the links at the end of the article. DD http://www.slantsix.org/articles/choke- ... adjust.htm |
| Author: | DusterIdiot [ Fri Jan 16, 2004 10:31 pm ] |
| Post subject: | Carb number? |
Something's up with that carb number. the 2295-2299 in the Carter series corresponds to the 1956 Mopar lineup... ???? -D.Idiot |
| Author: | Factoids73Dart [ Sun Jan 18, 2004 12:20 pm ] |
Yes, the carb says 2297 on the body of the carb. The Throttle lever doesn't have a spring on it, is that typical of the BBD carb? |
