It is currently Sun Nov 29, 2026 9:19 am
 Post subject: tranny leak
PostPosted: Sun Feb 01, 2004 12:07 pm
70 swinger 225 AT,70,xxx miles after driving,notice six inch puddle of tannyfluid below where engine and trans connects.sometimes don't drive it too often.Front shaft seal ????
PostPosted: Sun Feb 01, 2004 1:48 pm
Very possibly could be the input seal. Also check the filler tube where it is inserted in the case. (O-ring) also there are seals on the shift and kick-down lever. If you remove the access panel at the bottom of the bell housing and find tranny fluid inside, then you are probably looking at a input seal replacement .
PostPosted: Sun Feb 01, 2004 2:00 pm
Guest nailed it. I call it a converter seal. Do what he suggests.
