It is currently Fri Jul 17, 2026 6:46 am
PostPosted: Tue Feb 03, 2004 8:11 am
Hello everyone, I am finally about to rid myself of points and I was wondering if the alternator needs changed. I know that both upgrades are done at the same time usually. I just wanted to know if it is a requirement of the electronic ignition to have the newer stlye of alternator. Any help would be appreciated.
PostPosted: Tue Feb 03, 2004 11:47 am
Simple answer: No.
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
PostPosted: Tue Feb 03, 2004 1:13 pm
You might consider a solid-state voltage regulator, to help protect the electronics a bit better. There is a replacement for the old mechanical regulators, or you can get the 70-up regulator and connectors and do some wiring, as they switch differently.
