| Electronic ignition conversion https://slantsix.org/forum/viewtopic.php?t=8296 |
| Author: | mcnoople [ Tue Feb 03, 2004 8:11 am ] |
| Post subject: | Electronic ignition conversion |
Hello everyone, I am finally about to rid myself of points and I was wondering if the alternator needs changed. I know that both upgrades are done at the same time usually. I just wanted to know if it is a requirement of the electronic ignition to have the newer stlye of alternator. Any help would be appreciated. |
| Author: | mnecaise [ Tue Feb 03, 2004 11:47 am ] |
Simple answer: No. |
| Author: | slantvaliant [ Tue Feb 03, 2004 1:13 pm ] |
You might consider a solid-state voltage regulator, to help protect the electronics a bit better. There is a replacement for the old mechanical regulators, or you can get the 70-up regulator and connectors and do some wiring, as they switch differently. |
