It is currently Tue May 05, 2026 8:43 am
 Post subject: vavle body conversion
PostPosted: Wed Feb 25, 2004 7:33 am
In an earlier post someone mentioned making modifications to a stock valve body to make it full manual. Is this actually possible? I have searched the site looking for a procedure and cannot find one.
PostPosted: Thu Feb 26, 2004 8:07 am
There are "shift kits" available to accomplish this.
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
PostPosted: Mon Mar 22, 2004 6:58 pm
if you have access to a Direct Connection ( pre-Mopar Performance ) book it will spell out exactly how to make a full manual shift auto. this is NOT the hot set up for the street ! you do not have any passing / kickdown, just straight 1, 2, or 3rd gear, you can however boost your line pressure to a constant 90 psi with a simple ball removal, & line adjustment, add a new filter & gasket, begin start barking those 1st / 2nd shifts ! see Mopar Action article " Get Your Ass In Gear " E-Booger is right on !!!!!
PostPosted: Sun Mar 28, 2004 9:22 pm
although i regularly pick up mopar action, I don't have that article in my back stacks. How can I find that article or the other instructions you mentioned?
