| Poly front bushing Q? https://slantsix.org/forum/viewtopic.php?t=8537 |
| Author: | GTS225 [ Thu Feb 26, 2004 3:02 pm ] |
| Post subject: | Poly front bushing Q? |
I'm in work redoing a set of large ball joint upper control arms. Have the ball joints out, but figured I'd better ask a question before removing the bushings. Does poly UCA bushings need the outer shell from the original rubber bushings? I would think so, but should probably find out before destroying mine and having to buy and ruin a set of new rubber bushings just for the shell. Roger |
| Author: | kesteb [ Thu Feb 26, 2004 5:37 pm ] |
Most of the sets that I have seen require the outer shell. Most vendors suggest that you burn the rubber out of the bushing while its still in the A arms and slide the poly into the shells. |
