It is currently Tue May 19, 2026 4:55 am
 Post subject: Clutch jerking
PostPosted: Mon Mar 08, 2004 2:16 pm
Have Installed a New Clutch Kit Into my 1980 Ram 100 Pickup and everthing is New Disk, Pressure Plate Throw out Bearing, Etc.
Here is the question,
When I put it into 1st Gear or Reverse The Clutch is Jerking.
What would cause that??
kk4rb@mchsi.com
PostPosted: Mon Mar 08, 2004 3:30 pm
Did you resurface and clean the flywheel. If there's any oil on it; or, if the surface isn't smooth, flat, and of an appropriate finish.... You'll get what you just described as the clutch sticks & slips on the flywheel surface.
Another possibility is the transmission is out of alignment / slightly off-center.
Was the pilot bearing good?
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
PostPosted: Mon Mar 22, 2004 6:47 pm
should have resurfaced that flywheel ! is your disc release ( clutch fully depressed ) set with a feeler gauge ? maybe you now have enough clutch to show that the motor / tranny mounts are worn.
