| Clutch jerking https://slantsix.org/forum/viewtopic.php?t=8652 |
| Author: | emory2 [ Mon Mar 08, 2004 2:16 pm ] |
| Post subject: | Clutch jerking |
Have Installed a New Clutch Kit Into my 1980 Ram 100 Pickup and everthing is New Disk, Pressure Plate Throw out Bearing, Etc. Here is the question, When I put it into 1st Gear or Reverse The Clutch is Jerking. What would cause that?? kk4rb@mchsi.com |
| Author: | mnecaise [ Mon Mar 08, 2004 3:30 pm ] |
Did you resurface and clean the flywheel. If there's any oil on it; or, if the surface isn't smooth, flat, and of an appropriate finish.... You'll get what you just described as the clutch sticks & slips on the flywheel surface. Another possibility is the transmission is out of alignment / slightly off-center. Was the pilot bearing good? |
| Author: | Guest [ Mon Mar 22, 2004 6:47 pm ] |
should have resurfaced that flywheel ! is your disc release ( clutch fully depressed ) set with a feeler gauge ? maybe you now have enough clutch to show that the motor / tranny mounts are worn. |
