It is currently Fri Nov 27, 2026 8:43 pm
 Post subject: 8.25 axle question
PostPosted: Sun Mar 21, 2004 11:09 pm
I have a 73 8.25 axle housing, would later years axle 96+ fit, with proper bearings and diff?
also will a rear spring plate from a 8.75 fit on a 8.25 axle, or do you have to get an 8.25 spring plate...believe both housings are 3".....thanks...Jerry
73 Dart 4dr
70 duster
75 VW bug
ex-88 honda rice rocket
ex-70 cuda 383
PostPosted: Mon Mar 22, 2004 5:39 am
Either Mopar Action or Mopar Muscle ran an article recently covering this. They suggested using 96+ axles in place of the earlier ones because the axle where the c clip mounts is thicker. That would indicate that you should be able to swap the diff and axles into another housing as long as the axles and diff have the same splines.
I used 8 3/4 spring plates on the 8.25 Dakota axle I put in our Duster. They bolted right up.
 Post subject: 8.25
PostPosted: Mon Mar 22, 2004 1:49 pm
Rob....thanks on both answer....need to go thru the old issues of the Mopar mags...thanks....Jerry
73 Dart 4dr
70 duster
75 VW bug
ex-70 cuda 383
