It is currently Fri Nov 27, 2026 10:37 am
 Post subject: tranny adapters
PostPosted: Tue Mar 23, 2004 2:35 am
does anyone sell bearing retainer adapters (ring)to go from a 4.80 inside diameter to a 5.125 outside.use a hemi 4-speed on a overdrive four bellhousing?
there is only one...
PostPosted: Tue Mar 23, 2004 4:00 am
Call Wildcat wrecking in OR. Apparently you can use a later model 3spd bearing retainer on the 833 to convert the size.
PostPosted: Tue Mar 23, 2004 5:19 pm
Mopar Performance has the correct piece
