It is currently Sat Jun 20, 2026 5:00 pm
 Post subject: Harmonic Balancer swap?
PostPosted: Mon Apr 05, 2004 10:15 pm
I have a 71 D100 SWB and it has a 1975 /6 in it, I believe it's out of a Dart.
Anyway, won't get into the story as to why I need to do this, but I'm wanting to remove the double/triple (can't remember which it has) balancer/pulley off and put a single balancer/pully on it from my spare block.
Changing from a dual pulley to a single pulley, is that going to cause any crank balancing issues?
Scott Blaylock
Admin Sweptline.ORG/Sweptlineparts.COM
1964 D200 Camper Special, Poly 318, 4Spd
1965 D100 Utiline, /6, 3Spd
1969 D100 Sweptline, LWB, LA318, Auto, Factory Air
1969 D100 Sweptline Adventure, LWB, 383, Auto, PS, PB, Factory A/C, Tach!
PostPosted: Mon Apr 05, 2004 10:43 pm
Luckily the slant six is a neutral balance engine so all the cranks are internally zero balanced...in other words, the balancer off a 1987 truck shouldn't be a problem for a 1963 dart....
but:
the location of the timing mark did change in certain model years so make sure that when your swap it out you mark it for TDC in the correct location....
good luck.
PostPosted: Tue Apr 06, 2004 10:01 am
Good deal! Thanks! Just wanted to make sure before i swapped them. I don't need another issue LOL
Scott
Scott Blaylock
PostPosted: Tue Apr 06, 2004 3:31 pm
On the same note, the timing mark for TDC #1 is supposed to be 5 degrees off the keyway for a 71 timing cover, right? Thats what my damper was set to when it was rebuilt.... Can't remember if it was before or after though.
PostPosted: Tue Apr 06, 2004 7:26 pm
The other pulleys unbolt from the damper. You do have to remove the damper to unbolt the inside pulley though. :shock:
PostPosted: Fri Apr 09, 2004 7:12 pm
Finished up the swap last night and all appears to be going fine! I appreciate the help guys!
Scott Blaylock
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
