It is currently Fri Jun 19, 2026 5:30 pm
PostPosted: Fri Apr 09, 2004 12:31 am
I was going threw my grandfathers old parts, I found this Electronic Box that is clearly a mopar part. I compared it to my 77 and 79... they Both have these small black Box, it has a straight connector with 3 pins in it. It has 1 mounting ear hole on the top. I never really noticed this before, was wonder what it is and what it does, considering its not required for electronic ignition.... at least I think sense I never seen it used it conversions.
Mike C
http://cuda.iclownz.com
67 - Barracuda Coupe - 225 - Automatic
PostPosted: Fri Apr 09, 2004 1:08 am
Hmm... do you have a part# or picture?
Also, where is it on the cars you have?
PostPosted: Fri Apr 09, 2004 4:41 am
Tomarrow I will post the part number on it, sense its out in the shop. On my 77 Volare(225-2) its on the firewall... just right of middle just about the valve cover area. On my 79 Dodge Truck(360-2) its near the drivers side fender corner of the firewall...
Mike C
PostPosted: Fri Apr 09, 2004 6:05 am
E.G.R. Time delay.
A.k.a. Exhaust gas recirculator vacuum timer.
E.G.R.=
An emission-control system that directs some exhaust gases back into the intake manifold to reduce the formation of nitrous-oxide (NOx) pollutants. EGRs typically operate off manifold vacuum, and therefore only operate in the off-idle state up to WOT.
 Post subject: E.G.R. time delay
PostPosted: Fri Apr 09, 2004 6:09 am
Hmmm,.. Above post is mine. Forgot to login. :oops:
1965 Barreiros Dodge Dart. 225 / 4 speed.
PostPosted: Fri Apr 09, 2004 1:15 pm
Here is the numbers on it
427
3874310
Its painted Orange, unlike the ones on my 77 and 79 which are black.
Mike C
 Post subject: 387410...
PostPosted: Fri Apr 09, 2004 1:37 pm
Per the 1978 Mopar Parts Catalog is the EGR 'control' (read: timer) for California and High Altitude emissions package for all car lines.... (see Group 25 section 800 page 1 3rd part down...)
give the dutch dude a cookie... :wink:
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
