It is currently Thu Nov 26, 2026 10:10 am
PostPosted: Wed May 05, 2004 9:35 am
I bought the planetary gearset out of a A998 transmission at the Carnation, WA swap meat last Sunday. Will this work in my '63 pushbutton A904? I will be running a 2.94 ratio in the 8 3/4 (also a Carnation score, $300 complete :D ) and want the lower first gear. Are there any other parts in a V-8 A998 that I should use in my super-typewriter build up?
Thanks, Mark
'63 Dodge Dart GT, Super 225 2 bbl
PostPosted: Thu May 06, 2004 4:24 am
It's been a while, so I'm not 100%, but the cable trans uses a different input shaft/pump that might prevent use of this gearset.
The 998/999 uses a double wrap band that's stronger, but again, not sure if it will work in a cable trans.
PostPosted: Thu May 06, 2004 5:46 am
You can change the eary P/B 904 to the late input shaft, but you cannot use the low ratio planatary gear set. The internal splines on the planatary are different then the splines on the early output shaft. The output shaft on tne P/B trans cannot be converted.
PostPosted: Fri May 07, 2004 7:53 am
Ok, thanks for the info guys. I guess I'll just leave things the way ma-mopar intended. Thanks, Mark
Users browsing this forum: Ahrefs [Bot] and 20 guests
