It is currently Thu Jun 25, 2026 10:12 am
 Post subject: New Exhaust system
PostPosted: Fri Jun 11, 2004 9:58 pm
Hey there.
Finallly, after a long 2 months saving, I was able to install a custom made ex in my /6. It has 1 3/4" primary, 2" collectors and 2 1/4" to the end. It's 3 to 1 + 3 to 1. I can't tell you how happy I am. Not only sounds great, but revs up much more faster at lower throttle opening, has more power. I gues that the original 1 3/4 original pipes weren't enough for the engine... now I have special cam, tweaked carb (1 bbl but more cfm than a carter 2 bbl) shaved block and head. Runs like I always wanted my /6 to run. Does somebody knows how much ponnies a good ex can add? I feel a lot of diffrence, and not only in the sound. I even feel a diffrence in the shifting of my 904... but that may be just illusions 8)
PostPosted: Sat Jun 12, 2004 7:16 am
Headers can get you a 10-15% increase in HP.
In your case, where the cam and intake have also been up-graded, you will see even more increase. You probably gained 20 to 25 HP with your swap but most of that gain will be at higher RPMs.
PostPosted: Sat Jun 12, 2004 10:42 am
Thanks Doc. I really considered on buying your duals, but as I told you in another topic, getting that kind of heavy goods is a li'l tough in this country. I'll post a picture of my ex, so you can see how I solved the heat riser thingy and tell me what you think about that.
Thanks again for taking time to answer. Juan.
PostPosted: Sun Jun 13, 2004 6:45 pm
pix
 Post subject: looks good...
PostPosted: Sun Jun 13, 2004 7:55 pm
That's a good 'cheat', although I'd worry about long drives creating a 'heatspot' in the manifold. If I lived in Seattle or in the snow-zones that's what I'd do....
Other than that your exhaust system is "muy bonita"...
PostPosted: Sun Jun 13, 2004 8:46 pm
Thanks! i've drive tested that to ensure there's no hot sopt at all. After 3 hours driving in town (the worst panorama ever on a slant 6 for heating issues) the fuel was warm yet not HOT enough to bubble inside the carb bowl. Inside the "leg" the diameter is smaller, that leg is made outta 3/4" perforated solid stock, not tube.
PostPosted: Sun Jun 13, 2004 9:33 pm
Those are purdy looking bends. Do you have access to a hydralic bender?
PostPosted: Mon Jun 14, 2004 4:53 am
Yes, all the bending is made with hyd benders. I used a friend's bender (he has an ex shop) and expert hand with that tool. He has been making sport exs since 1959.
