It is currently Tue Oct 13, 2026 12:18 pm
 Post subject: Can I? With a Holley
PostPosted: Sat Jun 12, 2004 3:55 pm
just bought a super six intake and exhaust.. i was looking through summit and i wanted to put the Holley 2bbl 07448 carb on it.. my question is.. will this fit? if not.. then what carb would be good to run on this???
 Post subject: Two barrel mayhem...
PostPosted: Sat Jun 12, 2004 7:38 pm
With the super six the easiest swaps are the Small (super six and 318) Carter BBD.
Next on the list is getting a Mr. Gasket #1937 adaptor kit and running a Holley 2300 (like you're listing), you also with the plenum top adaptor from a Pinto/Mustang 1974-early 80's can run the Holley 5200/Weber progressive two barrel...
This will take some 'tinkering' to get it to run right. I think the Holley 2305 would be a nice carb to run , but they've been discontinued now for quite a few years.
If your slant has a stock cam, don't go over a 350 cfm Holley 2300 if you're going that route. I'd almost say you can comb the local wrecking yards for a rebuilder, I have one I' have yet to try, but it's numbered 80179, and is a 350 cfm with annular boosters for better signal and fuel spreading...this would work great on a stock mill where these factors will help mileage and throttle response.
If you have the use of a drill press you can make up some other adaptors for the other 'flanges' (like the big BBD off of big blocks, the Holley 2210 off 400's, or 2245 off of 360's...) out of aluminum chunks from a local scrap yard
The 2300 is a good carb if you have spare jets, shooters, accelator pump cams, and some time to really fine tune it in. It'll get you in practice for the day you decide to try a Holley 4 barrel...
 Post subject: Re: Two barrel mayhem...
PostPosted: Sun Jun 13, 2004 10:57 am
...no comment. :wink: :lol:
D/W
If it ain't broke, fix it!
 Post subject: Heh...
PostPosted: Sun Jun 13, 2004 11:01 am
I was wondering if you're gonna catch that Dennis. :wink:
 Post subject: thanks
PostPosted: Sun Jun 13, 2004 2:26 pm
i appreaciate the respone duster idiot.. i'm probaly gonna go with the 2300... i have a stock cam.. but i heard about Comp Cam's selling a cam that was just one step above stock.. i think it was the 252 s?
 Post subject: Yep...
PostPosted: Sun Jun 13, 2004 3:37 pm
I run the 252S and it's a good 'workhorse' up grade, lots of low end torque, keeps your gas mileage, etc...
If you're stepping up to the 4 barrel the 264 would be better...
 Post subject: holley
PostPosted: Mon Jun 14, 2004 1:26 am
would this fit?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW
 Post subject: Calling DUSTER IDIot!!!
PostPosted: Wed Jun 23, 2004 11:07 am
you said you had a holley 2300.. how much you want for it?
 Post subject: Yer Killin' Me....
PostPosted: Wed Jun 23, 2004 7:11 pm
That my only 2300, It's currently rebuilt and waiting for transplant onto my super sixed stock engine, or as a 'what if' alternative onto my HyperPak intake....
I should keep an eye out for more of these for board members...
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 4 guests
