It is currently Sat Nov 21, 2026 11:13 pm
 Post subject: 160Hi-Po
PostPosted: Sun Nov 13, 2005 6:31 pm
160HP hi-po 'Australian export' version 225cid used between '68 and '69 in the australian Valiant VE and VF models (these were Dart-bodied sedans, hardtops and wagons but with some frontal treatment changes) .. Does anybody have any experience with the peculiarities of these engines which 'rock' at idle (but only when hot)..?? Is this caused by the tappet clearances tightening-up and a feature of the higher-lift increased-overlap cam used in these engines..? They also ran 9.2 compression and had the same dual-throat Carter as the 318 on a modified inlet manifold. I've got one of these and although it outperforms a stock 318 A-body ..I can't get a decent smooth idle on this engine despite going to iridium plugs and fitting all new ignition parts. Thanks.. 8)
 Post subject: Re: 160Hi-Po
PostPosted: Sun Nov 13, 2005 6:48 pm
Not really an export version, it was an Australian domestic item.
Carburettor problems, too-tight valve lash, vacuum leaks, flat camshaft lobes, faulty distributor centrifugal advance causing fluctuating timing at idle, low compression in one or more cylinders...all the normal potential causes of rough idle.
Well...overly-tight tappet clearance, yes, but no, it cannot "tighten up" at idle especially.
No, that camshaft is nothing more or less than the 244° / 244° /26° cam used on all production slant-6s in North America starting in '71. That cam does not idle rough.
Only in the VF Pacer, which was unrated (guesstimated at 175 BHP). The regular VE-VF 2bbl 225 had standard nominal 8.5 compression.
No, a different Carter. Smaller venturies, smaller bores, an integral heat-tube style choke, and different jetting.
Actually an unmodified 2bbl inlet manifold.
Time for some systematic diagnosis!
PostPosted: Mon Nov 14, 2005 7:16 am
I would set the valves 0.002" looser than they are now and see how that works.
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
